Anyone have a suggestion on a good place to have Gears installed in Livonia or the surrounding areas. What's a good price to pay? I called Jack Demmer Ford and they wanted $540 :barf: not including the gears! I think that's way too high! Any help would be appreciated!
Thanks,
Andreas
Thanks,
Andreas
Alternative Auto Performance
145 Malow Unit D - Mt. Clemens, Michigan 48043
Phone: (586) 463-0010 - Fax: (586) 463-3194
Tell Lidio Ron sent you. Good luck!
Call DTS(DriveTrainSpecialist); they will charge you $450 total for gear change on your 98. That includes labor($200), gear ($150), bearings($100). Oh, the labor is a flat rate when they open up your pumpkin so you might want to think about changing the differential and axles at the same time.
They are located by 696 and grosebeck; extremely experience and fast(one day turn around for me). Their number is 810-778-0540.
call lidio @ alternative auto 586-463-0010, not cheap but not a rip off either. I had my gears done, they went above and beyond what they needed to...no extra charge. expect to wait a month or so since he is in high demand, plus its that time of year.
www.alternativeauto.com pricing on site.
I had my 4.10 put in at RC Trans & Gear in Royal Oak...they did great work and were VERY helpful in looking at the car (took it in twice at no charge and looked it over) when I thought they did a bad install, but it turned out to be a broken bell housing/pushed torque convertor (87GT) which was my fault....I HIGHLY recommend. Good luck!
