1 - 10 of 10 Posts
I recently purchased a set of AFR 165 heads for my 87 5.0. I plan to keep the stock cam. I may switch to the new Holley Terminator X in future.
Any suggestions for an intake? It is a street/toy car not a race car.
Ported upper and lower gt40 to flow 280cfm bolted together with the TB tunnel ported to 75mm and flow over 1,040cfm. That's all you need for that combo. It will make a ton of low/midrange and pull very hard up top without costing and arm or leg!
Explorer upper/lower intake from JY $100. $40 to have bead blasted. Have the lower ported for less than $200.
$340 or less
Sent from my SM-G960U using Tapatalk
1 - 10 of 10 Posts
