I did a quick compression test to see if any of my cylinders are down, and I got exactly 145psi on each cylinder. All even. Is that good for a b-cam?
When the car was tested before I bought it, 20,000mi ago, it tested 160psi on all cylinders...
Could my gauge simply be calibrated wrong? Both tests were done with the engine hot.
Were both test done with the "B" cam in the motor?
yep...I'm thinking it must be calibration....:confused:
yeah, try another gauge.
