1 - 20 of 185 Posts
Well guys figured I should start a thread on my latest build, car is a 88 regatta blue hatch, regatta interior no option car.
Goal is to have a streetable high 8 second car.
Motor specs
C9 Block 408, eagle forged rotating, srp pistons 28cc dish
Afr renagade 205 heads.
Fti hydrolic roller cam
Moral link bar lifter
Edelbrock Victor 351 efi with elbo 80mm accufab
Turbo kit, early hp performance
1 3/4 headers
Garett 76mm .96 a/r
Trans
Rockland standard gear. Transzilla t-56. Synchronize
Mcloud txt twin disc
Mcloud billet steel flywheel
Custom aluminu drive shaft
Holley hp efi
Holley boost controls with co2
Bbrc aluminum tanks
Magnafuel 750 pump
Narrowed 8.8 braced
Strange pro race 35 spline axles and spool
Ford 3.55 gear
Wolfe 10 point moly cage
Full length through floor subframes
Upr front suspension
Team z rear
13" cobra front brakes
11" wilwood fear with e-brakes
Finished Wolfe full length subframes
Wolfe 10 point moly cage, dash bar to retain heater box. Hammer tone silver paint
  • Like
Reactions: coupe1993
What it make on the dyno? That's alot of motor to breathe through that 76's hot side.
Havnt been on the dyno yet. Still waiting on the top end
Formerly known as 20thAniv
Very cool. You and I have the same goal. I look forward to seeing your progress.
subscribing and looking forward to updates
little surprised at the choice of the block and hope it lasts (i split my '69 and now running a dart)
Discussion Starter · #7 · (Edited)
Thanks guys. Not a ton of progress been working on my other fox's.
Got the cam degree in, heads on and motor dropped it. Hope to have the Trans in soon. Then into firing the turbo kit
Looks great - sub'd to see how it turns out!
What size rear tires and how much did you narrow the axle?
Discussion Starter · #17 ·
275/60/15 2" per side on the axle
1 - 20 of 185 Posts
