I'm wiring in my control pack, and wondering if I need to use the fuel pump circuit/relay on the Gen1 controller. I'm using an Aeromotive fuel pump, and have their relay and trigger wire.
If I don't use the fuel relay in the control pack will it cause a problem? Or does it make more sense to run everything through the controller?
Aeromotive has a bigger fuse than the controller - it makes me wonder about building the correct pressure.
TIA
Mike
TIA
Mike
