OK heres my deal ... I have a brand new complete gasket set for a late model 5.0 302 (a 1990 gt to be exact). What i was wondering is ...what gaskets wont work on my 393w. Would i be better off selling it and buying one for a 351w?
Inatke sides will be the same, end seals woudl be wrong but i use a bead of silcone ratehr than them anyways. Head gaskets will be the same, exhaust will be the same. Timing cover and water pump will also work. Timing cover seal is the same, not sure on rear main though.
You are in pretty good shape but depending on the parts and port sizes things could differ. But for the most part they will interchange.
you need to check the model year of the block to figure out whether it is a 1 or 2 piece rear main
sometimes on the intake gasket kits, it comes with both the 302 and 351 end seals...but if you bought everything in one kit it might not....i know if you buy just a Felpro intake kit, it usually has both...might check yours.
Jason
