ok im about to lower my tank to put on my battery box in the trunk.
i see a wire going through my trunk right next to where the box will be going. im guessing this is the gauge wire? do i have to disconnect this to lower it. and are there any other wires to take off before lowering it?
no
underneath there is about 4 conections though
one is the sending unit and theres one right in the middle of the tank. then you've got a connection at the fuel pump and i thin kthe return line.
do you know what that wire is then?
