I just recently blew a lower intake gasket running my bottle (which I sold after the incident) and I took it to a local Ford dealer to have it fixed/replaced. When I got the car back the gas pedal lightly sticks when I first push down on it. After driving it awhile it gets better but when I completely let off the pedal it will lightly stick again. Is there any way to fix/adjust this? It is getting very annoying. Thanks!
They may have adjusted the throttle stop screw to adjust your idle, try turning it in a 1/8 of a turn and see if it doesn't stick, happened to me before. Its on the bottom side of the throttle body/linkage.
I'm from St. Louis too, Ballwin actually. I'm at school in Springfield till Thursday. Where are you from?
STL
I live in West Co. too, actually Ellisville. Can't wait for WFC this weekend. Nothing better than driving 20 min to the best Ford event ever! I got alot of Friends around here with stangs too. Were trying to start a small club called Image Motorsports if your interested in joining. We should party sometime. Thanks for the suggestion!
did that work, with the throttle body or could it be something else,
mine sticks slighty too. it just needs like a lil extra push every now and then..???
Mine use to stick but only when the motor got hot... but putting a little bit of grease (not WD40) on there the throttle cable hooks up to the TB helps with the problem
