my gas milage used to be about 240 to 250 miles a tank, now i'm lucky if i get 180, any ideas on what to do to fix it. i'm thinkin o2 sensor and new spark plugs. is that right?
. ryan
I'd say do the O2s or get them checked, clean the MAF, what kind of driving do you do? I'm lucky to get 200 miles to a tank.
Go to autozone to get your codes pulled for free. Even if the car comes up with no codes, clean your maf and refurbish the k&n. Then run a tank of gas and see what happens. If no luck there then replace the plugs, wires, cap and rotor, and maybe the coil, just really give it a little tune-up. And if all this come to no gain in mpg then buy two new O2 senors and replace those and that should fix the problem if nothing else does.
