Real gt-40 intake tubular
Billet efi MSD dist 302
Billet carb 351 dist MSD
foxbody fiberglass doors with roll up windows
Built 8.8 tubes welded 31 moser ,4.30 ratio spool braces drum brakes
8.8 auburn pro 100 miles and went spool idk why but works only w moser axles 31 sp
A Ton of NOS stuff including industrial fill station and mother bottles w and w/o straw have bottle stand also for tank w/o straw ,if you want it ask ill see if I have but would like to sell all as package or trade for descent set of 180-200 cc
Heads .
Crower NOS roller cam
Pro sys carb 750 CFM
Various fuel sys for carb
351 Yorker and excelorator intake
Voodoo NOS FLAT TAP HYD CAM
Head stud girdles for Canfield and TW heads
Canton oil pan 351w
Plastic race seats w vinyl covers
Aod ,lentech and blue plate filled w JW bell T-brake w push button O/D 3500-4000 depending on what it's behind converter don't remember manufacture but it was bought from lentech so it's whoever they use, billet 300m input shaft w 4r70w grob style drums . Only thing this trans lacks to be strip terminator spec is the 31 sp output w adaptor and the upgraded 3/4 "direct " clutch drum .
In house upgraded T-brake sol . I had a lot of prob w the orig T-Brake sol bein consistent and sticking on. I grafted a much more reliable solenoid from a 4l80e trans to the sol they use which is a L/U sol for a GM 125 c or 200c trans.
Prob solved. Just refreshed always Amsoil filled .
This is a fixed line pres unit so no tv cable nessisary .
Various Auto meter gauges
Fiberglass cowl hoods 3" 4" 6"
Rear window lovers for notch and hatch
Roller or non roller previously cert to IHRA 8.50 87 notch
Make serious offers and all will be considered
I am looking for a long or short block for 20-25 lbs boost
Shaft rockers for Vic sr heads
Ex valves for stage 2 Foxlake Vic sr
Intake for 8.2 w Vic sr head efi or carb . Dominator flange preferred but let me know what ya got
I have set of std bore 326 .250 domed JE pist for use w 3.25 stroke and 5.400 rod and need the equivalent for boost sale or trade.
Willing to trade rotate for rotate if nessisary
Mine is Callie's and Carrillo based .
Also have m122 from 2011 gt-500 w less then 100 miles
Open to all offers cash or trade .
Inbox me w your needs even if I didn't list it I prob have it.
Heads .
Canton oil pan 351w
