Cleaning out garage and need to get rid of some stuff that I haven't used in
awhile and could use a good home.
Set of Harland Sharp Shaft Rocker System for TFS Twisted Wedge Track Heat (Non R) Heads. These have 10 easy passes on them. Switched heads and have no use for these. These are specific to the TW and will not work with others. Paid $1100 new asking $500.00
Edelbrock Super Victor- Part number 2928 8.2 deck motor. Gasket matched bolted down ran and removed. Paid$340 new from Summit Asking $250.00
Set of GRP Billet Connecting Rods- These have an honest 3 passes on them. They are 5.400 long with a .927 pin, .831 big end width. These have a Ford 2.3 or 2300 bearing size which is 2.046. To use these on your favorite Ford motor you would have to turn your journal down to this size. Used to offset grind for stroker motor. Bearing included but will need to be drilled for dowel.
These are around $1000 new, asking $500.
Not desperate so no lowballing. Thanks
Thanks for your time.
