1 - 1 of 1 Posts
do you think it's possible to use an older mechanical/vacuum advance distributor and install the hall effect sensor on it to gain timing control. then you could adjust the timing curve to whatever you wanted and the hall effect would keep the computer happy and tell it when to fire the injectors. i've already taken an efi distributor and converted it to hold the old style small cap and rotor so fabrication is not an issue, just a matter of mr sawzall and a welder. lol
1 - 1 of 1 Posts
