After f'n around with intake gasket crap, now I have oil pressure crap.
Stock-ish bottom end build 5.0.
Stock block, rods, crank, .020" over.
HCI + exhaust.
Nothing crazy.
Cold engine (70-90F), stock oil pressure gauge is a hash or 2 above middle and steady regardless of rpm.
After driving about 5 miles, oil pressure is down to about 1/4 up from low on stock gauge when running at about 1700rpm on highway (2.73 gears) when hot, which seemed low to me.
Above about 2500 rpm, gauge is right around the middle, maybe a touch under.
Idle it was dropping down to bottom hash mark.
No unusual noises that I can tell.
I know it wasn't that low at the beginning.
Running 10W30 conventional oil, fl1a filter.
First oil change was after about 30 miles so current oil/filter is around 500 miles.
Primed engine before first start and had about 60psi on mechanical gauge.
Hoping it was just the crappy factory gauge/switch, I connected a HF mechanical gauge and it was sitting at about 15psi at 800rpm idle hot.
Rev it up to 3k rpm in neutral, gauge goes up to about 30-35psi (I cant remember exact number).
I plan to connect the mechanical gauge cold and take it for a drive to see what it shows as oil heats up.
I assembled this engine this spring.
I had the block bored, decked and the crank polished and balanced (with my balancer and flywheel) since it was the only new(er) part.
Bearing clearances checked. Mains were a little tight at .002-.0023, but not crazy.
Rods were right around .002-.0025"
Melling M68 pump.
Front oil plugs were threaded/plugged.
Really just your regular stock build.
I haven't beat on it really.
Small stack of pulls up to 5k rpm and 1 or 2 up to 5500, but mostly mix of city/highway driving.
Doesn't burn any oil.
Oil is still light in color, but I haven't been able to really look for an shiny flakes.
I plan to drain oil and cut open filter this weekend, but I'm worried that engine will be coming back out.
I'll run my borescope up into the oil pan see if I can spot something obvious.
What are chances it's not serious?
I should have left the other "full home garage" stock rebuild in the car.
While it had no power above 4k rpm, at least it idled and drove like a stock engined foxbody.
HCI + exhaust.
Nothing crazy.
Melling M68 pump.
