Hi there Stangers
I just got my new Steeda G-Trac bar from the UPS guy today. I was lookin over the instructions and it seems like its a pretty straightforward job. Has anyone thats done this before encountered any problems? Or came accross something unexpected? Also what did you notice after the install. What should I expect? Any noticable differences?
Thank you in advance.
it is probably the easiest thing to install next to a K&N filter!
Just remove the stock bar, and bolt the new one on.
As far as noticing a difference, I did. But I have both swaybars removed though. Don't expect anything drastic.
I just bought it because it was cheap and for $35, you really have nothing to lose.
Beats me why you bought it???
It will do no more than the stock unit.
If you want to stiffen up the chassis install SFC's and a STB.
Then get the X brace from under a vert.
I got mine from a junk yard for $50.
That attaches to your lower K by 6 bolts then goes out to tie the rocker panels in also. It really tightens up the platform and stops the twisting and flexing.
Dwayne
