PLEASE HELP!! HOW CAN I MODIFY MY STOCK 302 RAILS TO FIT A 351? I WAS THINKING ABOUT JUST CUTING THE RUBBER HOSES AND EXTENDING THEM WITH HIGH PRESSURE FUEL LINE. HAS ANY ONE DONE THIS? I'M AFRAID IT MAY SLIP OFF UNDER PRESSURE.
Will the stock fuel rails supply enough fuel for the 351? Or is it a "mild" set-up? I was under the impression that once you went to 30lb injectors, you had to go with aftermarket fuel rails. Perhaps I'm wrong.
