what fuel pump do you run and why? what brand would you not use? thinking it is time to replace the stocker and go with a higher output aftermarket. engine is basically stock, but may change over next winter depending on finances. possibly a 331, still up in the air. what brand and lph do you fellow corralers recommend for me.
thanks
erich
I run the Walbro GSS340.. which is the 255-LPH "High Pressure" intank pump.
This is what I would go with if I were you. It doesnt cost that much more than a 190-LPH and this way you'll never have to upgrade.
-Franklin
