I need some fuel pump advice. I've got a GT-40 crate motor, and am planning on adding a 100 or so shot of nitrous. would a 190 lph in tank and a T-rex in line pump be sufficient? could i run a switch for the inline and just use it when on nitrous, or should i just have it on all the time? also, are 24# injectors sufficient for this set up, and what fuel pressure should a setup like this be run at? thanks ya'll!
Aaron
You can probably get by with just the 190 with a 100 hp size Nitrous kit. It also depends on whether or not your going with a wet or dry system. As far as FP is concerned, you need to pay more attention to the timing, as you will need to retard it a bit to keep from detonation problems.
