I have an 88 lx aod. It has
24 lbs injector
70 mm throttle body
bbk cold air intakecobra intake
4.11 gears
I cam but i don't know which one, it was in the car when i got it
fresh tune up
the car just feels weak
it has
40lbs fuel pressure with vacumm
45lbs without
is this to much fuel pressure
any help would be appreciated
yep too much pressure. Stock is in the 39-40 psi range, and with your mods it will most likely run better leaned out a bit. I would try dropping it down to around 38 and see how it runs. I'm assuming your heads are stock, so the 24's are alot for it anyway, but 45 psi with vacum off is way too much.
Is the car Mass air. All but California cars were speed density in 1988. If speed density, it will have a problem with 24# injectors and aftermarket cams.
