Hey guys, just did a rebuild on my 94 cobra and slapped a turbo on at the same time. New walbro 255 intank, new fuel filter, new kirban adjustable fuel pressure regulator, new 60 lb injectors with matching pro-m mass air, also went ahead and had a chip burned for the new setup just for initial start before I take it to get tuned.
Anyways, I turn the key to on and the fuel pressure jumps to just under 40psi according to my fuel pressure gauge. I turn the car over and the pressure stays the same and the car starts. Then as soon as it starts running the fuel pressure drops to 0 and the car dies instantly. This is a repeating process.
If i dont try and start the car, but just turn it to on, it builds just under 40 psi and will hold it. It only drops after the car has started. What do you guys think? The terminals on the computer were fairly clean when I installed the chip but I still hit them with scotchbrite. Thanks
