Is there something wrong??
No...Fuel pressure should not drop during acceleration. Is this with a full tank of fuel? Sometimes the pick-up can be inserted into the tank but not in the correct fuel well.
Check the voltage to the pump to be insure no voltage drop when the engine is revved at Idle.
Good Luck
AJ
I have not checked it while under load, but when I rev the engine from idle it drops. Could this be causing my low rpm miss?
I just got done with a TFS combo, and My FP drops when reving too. But thats normal from what I heard with no load. Try it with load and then you will seea diff.
