I've got the stock fuel rail set up and I cut the fuel lines when doing the engine swap and now I'm putting everything back in its place and I realized that I forgot to label which rail line goes to which line going back to the tank along the frame rail
could anybody tell me which lines goes to which
on the frame rail there are two lines, one is in front of the other coming off the frame rail, and on the intake there is one line coming down that has the Shrader Valve and the other is just a line
I don't know if there is an inlet line and outlet line or if it matters which line I hook to which, but I just want to be sure
thanks
Jim
The one with the valve is the incoming fuel.
