Power Adder Solutions is a Proud dealer for FIC products, proven results tested in house on our Dyno please post up your needs or any questions.
PowerAdderSolutions.com - Ford Mustang Specialists Custom Tuning
Office: 1.919.779.4153
M-F 9:00-6:00pm
Fuel Injector Clinic injector sets are precisely flow matched to within 1%. Each injector within each set is individually numbered and results for each injector are listed on a detailed flow sheet included with the set. Dynamic flow matching is used only on injector sets where the additional time and cost are justified by the corresponding benefits gained during the tuning process.
Fuel Injector Clinic injectors are flow tested and rated at 43.5psi (3Bar) at 75ºF average fuel temperature using CF-16B calibration fluid.
The superior spray pattern and atomization make these injectors easy to tune and provide great drivability.
Fuel Injector Clinic injectors are set up to and include all o-rings needed to fit the factory application for the listed vehicle. For aftermarket or other unusual setups please contact us prior to placing your order to make sure you receive injectors that fit properly.
Every injector is covered against failure caused by defects in original manufacture by our 12 month warranty.
Fuel Injector Clinic injectors use the factory electrical connector or include solder-in pigtails. You can purchase adaptor ‘plug-n-play’ harnesses to avoid cutting your stock harness as an optional extra.
This injector set contains high impedance injectors matched to the saturated injector signal generated by this vehicle’s OEM ECU, OR is suitable for use with an aftermarket ECU made or set up for high impedance injectors.
