For you guys out there that have done a fuel injection to carb conversion, can you tell me the things i am going to need to do this project??
Exclude the lower intake and carb, even i know that one...
I have a 93 5.0 engine going in a 94 LX SN95 body.
Thanks for any help you guys can give me!
you will need a complete ing.,new fuel system with fuel cell (easiest way to change over) and all new gauges unless you can figure out how to wire the gauges out of the 95.you will also have to run a bigger fuel line because carbs need more volume than pressure.i use the holley blue pump with an areomotive regulator and my car runs fine.email me if you have any questions at [email protected] and i will be glad to help
