-90 mustang v8 STOCK-
STEPS I TOOK TO FIX:
Fuel gauge was not working. Dropped the tank and put in a Brand New sending unit. Among new fuel pump.
Gauge barely moved and bounced around a little bit.
Thats when I replaced the Anti-Slosh on the back of the cluster.
Still got little to no movement on the gauge.(filled tank drove it for a few days and filled back up) nothing.
Ended up grabbing a new cluster (my uncle dropped and busted plastic off mine) Seen new cluster working when I purchased it.
Installed new cluster and still the same situation.
IS THERE SOMETHING ELSE CAN I CHECK?
I was thinking possibly a grounding issue?
I would make sure you do not have a short.A shorted wire would cause it to read empty and an open could make it read full. There is a good article on the web that covers troubleshooting the fuel gauge/sender circuit.
Make sure you didn't blow the fuse that feeds power, then check the ground which I believe is between the tail lights.
The ohm reading should be between 22(empty) and 145(full).
PM me and I can send you some screen shots out of the manual if you need them.
Discussion Starter · #4 ·
That would be grea if you could send me some screen shots when you have a chance.
