1 - 20 of 27 Posts
!!!SOLD!!!
Fox Body 5.0L Twin Turbo Setup For Sale
Included as pictured: Twin Garrett T3 Turbochargers from Thunderbird Turbo Coupes w/ the larger .63A/R exhaust housings. Twin Super coupe intercooler setup. 1 5/8” BBK Shorty Headers with 2.5” exhaust tubing into T3 flanges. 5 bolt pattern turbo exhaust flanges into 3” exhaust downpipes that dump past the bellhousing below the tranny mount. Included with but not fixed to be included are 42# injectors, a 90mm Granatelli Mass Air Meter, and a Snow Stage 2 Boost Cooler MAF digital reading Methanol Injection system.
This setup as is put down with my 331 stroker, 577HP and 666Ft.Lbs. TQ at the wheels on a mustang dynometer. The car and this setup for that matter is typically street driven less than 3000 miles each year and taken to the track at least twice a year. This setup configuration as it is has been on the car for 2+ years coming into parking it last winter.
The passenger side turbo is as solid as they come. It hasn’t been off the car for any maintenance or issues for its sake since its been on the car which has been a few years now. The driver’s side turbo has play and does burn oil. For this reason I am including my spare backup junkyard pulled T3 that can be swapped in place with the larger exhaust housing. This spare turbo has not nearly the endplay of the going bad driver’s side turbo but not as tight as the passenger side turbo. Purchaser can either swap the spare straight in or purchase a rebuild kit for less than $100 or spend good money and go with a professionally balanced rebuild for $400. Some clamps, intake manifold to cold side piping hose coupler are needed as i stole them for my current setup and obviously you will have to tap your own oil feed and drainbacks. barbed oil drainback flanges are on the turbos and one still has an oil return hose on it.
The entire kit, spare turbo, injectors, maf, and methanol inj: asking $1,500
more parts will be added shortly.
Blame Canada!!!!!!
would u sell just the turbo's?
sorry i'd rather not seperate the turbos at this time but if someone were to buy the hot and cold side pipes and not the turbos i'd be more than happy to do that for u.
What accessories were on the car? power steering and a/c? If those werent on it, would they it it if they were?
Discussion Starter · #5 ·
ah very good question i did not address in my original post. The turbo setup was for power steering but no A/C. I would not imagine this setup having room to run A/C and P/S if that answers your question. I can't be 100% certain either way but my best guess would be sorry you couldnt run ur A/C.
Blame Canada!!!!!!
ready to let just the turbo's go yet?
Discussion Starter · #12 ·
still no offers on just the piping. if that sells first then obviously i'm left with the turbos to sell and u'll be ther first to know. risky selling the turbos first is all and harder to find a buyer for a JYTT piping kit by itself.
Blame Canada!!!!!!
buy em up bulldog i need the turbo's
free bump for ya Dappie
Discussion Starter · #17 ·
bulldog44: PM sent
Stangman308: thanks sir. I'll keep u updated if the kit gets split as i know ur interested.
Strub1975: won't split those parts just yet from the entire kit. will get back to you via PM if the hot/cold parts of the kit get sold then i'm willing to split everything else.
1 - 20 of 27 Posts
