1 - 19 of 19 Posts
· Registered
351 Windsor Block
4340 418ci 4.1 Crank
H-Beam Steel Rods 6.200
22cc Pistons
1 piece rear main
Setup for 28oz external balance
Dominator Timing Set
New high volume oil pump and heavy duty shaft
Main Girdle
ARP Rod bolts
ARP Main Studs
ARP Head Studs 12pt
Electric Water Pump
Professionally assembled.
Cam Installed: Comp Cams custom grind
5.86/6.10 lift
236/244 duration @ .050"
114 deg lobe separation (EFI friendly)
Hydraulic roller grind
Cam matched for valvetrain and heads
$3990
Pics at http://creceveur.smartboxllc.com/forsale/
1 - 19 of 19 Posts
