Switched out 4 lug and brakes off 1993 cobra to 5 lug and brakes off 1995 GT. The back brakes work fine. But the front brakes doesn't work very good. They go to the floor. The front brakes have been bled and everything. But they still don't work very good they just go to the floor. But the back one work fine. Does anyone know what is wrong?
Did you swap the master cylinder as well? If not, the larger calipers will drain the old master cylinder and require further pedal travel. If that's not the case, then your proportioning valve may be shot. Getting brakes at the back and not the front; I'd say that's the problem right there.
