Upgraded TK0 500 5 spd transmission with all the good stuff installed to make it even stronger compared to a stock TKO.
Freshly built and fully inspected with several new parts recently installed from Hanlon Motorsport receipts to prove.
($2500 in parts and $1000 labour to install).
Removed from 1988 fox body Mustang 5.0 but will fit many other years and applications.
Features:
McLeod RXT Street twin disc kit 26 spline clutch
rated at 1000HP Part #MCL-692303 with application tool. ($1600++).
FMS Performance Billet steel flywheel 157 tooth
50oz Part #M6375C302B. ($400+).
Steeda Tri-Ax short throw shifter Part #SDA-555-7456
($300+).
FMS bell housing, FMS clutch fork with new clutch cable, pivot ball, FMS throw out bearing, ARP flywheel bolts, cross member, new tail shaft seal, energy suspension poly trans mount and more.
Perfect for a fox body manual conversion or upgrading your weak T5 to something much stronger.
Asking $5000 for the entire package OR
$6000 with the McLeod RXT clutch.
Features:
- Heavy Duty TKO construction.
- Gear ratios: 1st 3.27; 2nd 1.98; 3rd 1.34;
- Improved carbon lined 2-3-4/brass blocker rings 1-5
- 4615 steel gears for increased torque capacity
- Torque capacity: 650lb ft.
- 26 spline input shaft
- 31 spline output shaft
($300+).
