1 - 20 of 21 Posts
Blow Out Price on the infamous FR500 Camshaft Kit.....NIB!!!​
$825.00 plus S/H
This is HALF PRICE!!!!
It's got to go!​
*Fits 1999-04 production 4V DOHC 4.6L cylinder heads
*Excellent power to 7000 rpm
*12 mm lift, 258 degrees intake and 254 degrees exhaust, 109 center line
*Kit includes cams, valves, valve springs, valve seals and followers
*May require calibration to achieve optimum performance
This kit works for 96-98 cobras. It was initially on a B head I believe as the FR500 was an SN95 body style? Anyways a great kit for N/A motors and can't beat the price
Nope, these were never used on B heads and the FR500 heads are totally different. However, the entire kit will work with B heads.
Crap. If this had come up a few months ago...
Bump for you.
Can you post some pics of the kit and comfirm that it is NIB and not missing any parts??
Discussion Starter · #11 ·
I'm NOT pulling everything out of the box and taking pictures. All that stuff will never go back in the box.
If you have any reservations, I suggest you don't buy it.
Hold on there cowboy.... you have no trader feed back, the economy sucks, and poeple are running scams all the time. Do you have a pic of the box, or could you take a pic while opening one end of the box???
If you are for real, I will buy it right now, I just want to make sure I am getting the real deal with no missing parts.
Ford Racing is selling these for only a little more that what they are being sold for int his thread. With that, there shouldn't be any concerns that this price is too low and should worry about a scam.
BTW, a box would tell you nothing other than he has a box.
If the OP is who I think is you have no worries.
By posting a box instead of the Ford pic above, I know that the OP has the item, I also get to verify the part number. And if he would only be kind enough to open the box and post a pic that would give me some more confidence on buying them.
How much of a HP increase do you get with this set up with a NA motor? How would this kit compare to something like a comp cams stage II?
Discussion Starter · #18 ·
It really depends on your current mods.
Remember, This is a kit and comes with far more than what you can buy from Comp as a kit and for a FAR less price.
VERY true.
This kit was a (relative) bargain even when it was ~ $1400 due to all the parts included in addition to the cams themselves.
At $825 it's an absolute steal.
1 - 20 of 21 Posts
