For sale Foxbody 302 based Vortech V2 kit with lots of extras.
Head unit was serviced at supercharger rebuild.com new impeller seal, new front shaft seal, and new front case o-ring in summer of 2019. Hardly any miles on it maybe between 250-500 miles since gone through. Street miles only never even made it to the track. Bearings are good, gears good, no shaft play made 12 lbs of boost at 5,800 RPM on a 306 10.5:1 compression with the 3.125 pulley and a 7-in ASP lower crank pulley. Never spun it any faster than that but I do have a 2.95 pulley that has never been installed or ran on this current set up.
$2900 shipped. Would prefer Zelle payment on this but if you want to pay with PayPal then I can work with that and please add 3% for PayPal fees.
Complete Foxbody kit every bolt every nut all the clamps all the brackets two head unit pulley's two blower belts one belt is new never ran. One accessory drive belt for a Ford motorsport a/c delete set up dayco poly grip 5060810 with stock power steering pump pulley. Aeroquip -4 oil feed line, Aeroquip -8 oil return line. Polished head unit polished discharge tube. Turbosmart 34mm blow off valve and customized piping and hoses to fit UPR power pipe power that's mated to a lightning 90mm mass air meter with foxbody wiring harness pig tail included with K&N 4" dia 6" long filter. Asp 7 inch crank pulley with under drive accessory drive pulley. ASP 93 Cobra water pump pulley. Custom aluminum blower belt tensioner pulley with two different size belts. One that fits the 2.95 pulley that is unused a gates fleet runner K080545HD. Another belt that fits the 3.125 pulley a gates fleet runner K080550HD. It also fits a 3.33 pulley but I do not have a 3.33 pulley any longer. SR performance smog pump delete pulley and alternator stay bracket. I will be shipping the head unit in a Vortech head unit box by itself with the foam padding made for a head unit and the rest of the parts in another box. Both the 3.125 pulley and the 2.95 pulley have been carbonite coated by carbonite coatings no slip lots of grip. 95' SN-95 5.0 upper radiator hose modified to fit the Vortech in a foxbody with clamps included. Here's pictures of the kit on the car and the head unit after I cleaned it and Polished it before installing 5 years ago. And pic of bov and hoses the fit power pipe.
