LISTING FOR A FRIEND. KIT IS LOCATED AT ZIP 23417 PM FOR HIS NUMBER.
Selling a vortrch v1 s trim kit 8 rib designed for use with a fox body mustang. Kit is an 8 rib kit and has the original straight cut gears. The headunit spins freely and comes with new feed and return lines and includes all new piping and upr power pipe, new smog delete pulley, new deca 60 injectors and new pro m 80mm maf calibrated for 60lb injectors, all new vortech charge piping and vortech bypass, and new appropriate heat range plugs. The only thing you should need is larger fuel pump and tunning. I originally purchased this kit and began upgrading it but ended up selling my fox body. This kit will also work for 94/95 cars but requires a different bracket.
