Hi!
I have a 1989 Mustang GT that's running lean. There's no check engine light while driving but after testing for codes I got a "41" and "181". It has a bit of a loss of power and tends to stall and stops. I've done lots of work to the car including new plugs, cap and rotor, TPS, O2 sensors, fuel filter, air filter, EGR, TFI, ignition coil, and cleaned the MAF. I've checked for vacuum leaks using this stethoscope my dad has and couldn't find any. I did a base idle reset with TPS, has about a .96. Vacuum was good until the idle dropped down after a few seconds. Still need to check the fuel pressure. The fuel pump was replaced not too long ago and I've been giving it treatments of fuel injector cleaner, "STP High Mileage".
If anyone knows anything that'd be awesome, thank you!
