Anyone know the proper size of the rivets used to mount the door window regulators? I have to replace a few and not sure if they are the same as used for the exterior door handles.
EDIT: using a nut/bolt will not work as the area between the regulator and door shell is too narrow. The rivet seem to be the only way to go.
I believe they are 1/4 inch
yes, 1/4" and you better have a good rivet tool to "pop" them. I have a pneumatic/hydraulic one at work and absolutely love it for doing these.
Thanks everyone. I have a Marson big daddy rivet tool so that should do the trick.
