just for the record swapping the 460 in the fox body is not as expensive as you think, first you dont have to buy the $1000,00 kit ,you can use the 84 ford truck oilpan ,from the local scapyard, they are identical to the kit pan, the motor mounts you can make yourself ,if you have a welder, or shop near by, the headers D&D mustang will help you with , or Jeggs, the best thing to do go to the boneyard buy a 460 truck motor, Booom!!! There you go
Yes but you would want to use a late 60's through 70's block. More durable.
Agreed 100% on the D&D Motorsport headers. Stay away from Hookers! Lol
It will bolt right into any after market tubular frame for a 5.0.
