A customer gave these to me and I have no need for them. I am currently moving and need a quick sale.
These only have about 10 passes on them. Like the title states, they are fox length 28” and have the Strange brake calipers and bearings pressed on. There are some bent studs that have to be replaced due to customer using thick spacers. In order to remove the screw in studs the bearings will have to be pressed off. Brake brackets will not allow removal. These are set up for use with 9” Torino ends. 2.5” brake off set.
$400 shipped
Road surface Automotive tire Asphalt Wood Grass
Automotive tire Wheel Bicycle part Motor vehicle Rim
