ive got a 92 that just turned 54,000 miles, i just completed a cam intake swap, i put a trick flow stage one cam, with a ported gt40 lower and cobra upper, other mods are cold air kit, msd coil,cat back, headers, hpipe,373 gears, king cobra clutch,what should i expect putting a 75mm tbody and mass air?thanks!
75mm tb is quite a bit too big for your combo as it sits. A 65 would be a lot better for it, only time you need to go bigger than a 65 is with forced or more cubes. You won't lose horespower, you just won't have the same throttle response. I'd go with a 65mm tb and a 75mm pro-m
What do you think about just the mass air meter and smoothing up the t-body, i removed the screen allready?
well, I'm not really sure about your future plans for the car, heads, nitrous, etc. but I would go with a pro-m meter definitely, and you can get it re-calibrated for bigger injectors. For right now though, I would pick up a set of 24# injectors and a 75mm pro-m maf. For the tb, maybe see if you can pick up a cheap 65tb, like an explorer, I'm not sure what kind of budget you are on. And if you go with new injectors/maf, definitely get an adjustable fuel pressure regulator. Everyone I know, including myself, has had good luck with the kirban one, and its only 70 bucks or so.
I'd say heads next, that would open it up quite a bit
Hell yeah it would! Just ran mines last night for the first time after cam and head swap. Previous best was 12.48 @ 109, new best on shakedown run, 11.86 @ 117. Couldn't make another run though, tried to talk to track management for another run but got denied untill I get a bar in. (Fair enough) I know she's got a 11.6 in her right now. Oh well, will get a 6 point in and dump da squeeze for my ATI P1SC-2, damn can't wait!!!
budget, ha, yeah not much of one, im looking for the most bang for the buck right now,so my choice was a small nitrous wet kit:lol: ive seen many bangs over the years that cost lotsa bucks!im wanting to keep this just as drivable as i can, id like to put heads on but ive also got a coupe that im planning to make a monster one day,ive been batting around the idea of porting a set of e-7s, or finding a cheap set of aluminum heads,i do plann on getting the regulator, and upgrade the pump, i like the idea of the explorer t-body,ive got a steak appetite on a bologna budget!
