Gaging interest on making some adaptor brackets to mount Foxbody driver's side accessories in their standard 302 location on a 351W.
Why would I do such a thing when Ford Motorsports already has a bracket available for a reasonable cost? Because when you use that bracket with a Procharger, the supercharger ends up inside the inner fender. Alternatively, the race-mount drops the S/C in place of the AC... but I live in Georgia and I like my AC.
Anyway, chime in if you'd be interested in buying one of these. The final price is likely going to be less than $250 and will include the mounting hardware for the head, AC compressor, and power steering pump. If there's any interest I'll procure some AFR heads, GT40 heads, and some E heads just to verify proper fitment.
Here's the adaptor bracket bolted to a RHS head on a 351W stroker. The plate starts as a 1" billet aluminum and is CNC machined with stand-offs pressed in. This is only the prototype, though it's functional. The final will have 2 large lightening holes.
The alternator is bolted to the plate, then the plate is bolted to the head.
The stand-offs are for the powersteering pump mount; the AC compressor receives 2 thin spacers
The completed assembly places the S/C in the same position as it would be on a 302. Keeping the accessories close could also be beneficial to turbocharger installs
I'll be putting a new bracket brace together, likely picking up on a longer bolt through the AC compressor. Regardless, the assembly is nice and solid with 1 additional attachment point on the head over the stock bracket.
Dave
Dave
