I found this pull cable loose behind my stereo w/ a plastic mount but not sure what it is for. Remote gas door is possible but the door is good 'ol stock manual type. All the Heat and A/C controls work OK. Any ideas? Started to rain so I had to stop digging under the dash. '92 LX.
JL
My car has one as well. The reason is because my car used to be an AOD. I bet it goes to the column to lock the ignition when not in park.
I bet your car was an aod.
Was it a AOD before or after you got it?
I am glad you got it figured out. Mybe you could jump over to my post about suspension and return the favor. I am lost.
The pedals was not too bad to me. The AOD sucked getting it out. It was heavy, bulky, and the pins was siezed which would not allow it to come out.
