I have a P-1sc with 2 core intercooler and i found that one of the tubes(elbow) that connect close to the intercooler itsef has a slice(about an inch or less looks like a razor slice) in it i can stick my finger tip in it if i push hard enough.. Will this hinder performance in any way, or mess up my idle?
Yes it will hurt performance. Under boost it will leak and you will loose pressure thus reducing HP. If you can patch it using an approperate glue and patch do that. I would recommend you get a new tube asap.
Dwayne
Yeah, I would replace that ASAP. Under boost, that cut may enlarge as well. It is hard to find that exact tubing. You may have to order from ATI.
Erich
