1 - 1 of 1 Posts
STREET LEGAL CAR HAS RUN ON THE DRAGSTRIP, CIRCLE TRACK, ROAD COURSE AND LAND SPEED RACING. 156 MPH IN THE OHIO MILE. THIS CAR IS PRIMARILY SET UP FOR THE ROAD COURSE.
ENGINE: 351W, HERBERT CAM, PORTED C5 HEADS, 1.94” INTAKE VALVES, 1.6” EXHAUST VALVES, ROLLER ROCKERS, STUD GIRDLE, OFFENHAUSER 360 INTAKE, 750 HOLLEY, WRAPPED FORD SHORTY HEADERS, GLASSPACKS, LARGE AFTERMARKET ALUMINUM RADIATOR AND FAN WITH ADJUSTABLE CONTROLLER. CUSTOM ALUMINUM AIR DAM, OIL COOLER.
FUEL SYSTEM: QUANTUM IN TANK 265 LITER/HOUR PUMP, HOLLEY BYPASS REGULATOR
TRANSMISSION / CLUTCH: RAM TRIPLE DISC ASSUALT WEAPON CLUTCH, ADJUSTABLE CLUTCH QUADRANT, TREMEC 600 TKO 1ST 2.87, 2ND 1.59, 3RD 1.28, 4TH 1.00, 5TH .64, R 2.56
BRAKES: COBRA DUAL PISTON FRONT BRAKES, STOCK REAR DISK BRAKES, STAINLESS STEEL BRAKE LINES
REAR AXLE: 9” FORD WITH MOSER 4.11 TRUE TRAC, 31 SPLINE AXLES
FRONT SUSPENSION: MAXIMUM MOTORSPORTS TUBLAR K-MEMBER, MAXIMUM MOTORSPORTS .75” OFFSET TUBLAR CONTROL ARMS, 3 WAY ADJUSTABLE KONI COIL OVERS, BBK STRUT TOWER BRACE, MAXIMUM MOTORSPORTS BUMP STEER KIT AND OFFSET RACK BUSHINGS, 2001 FRONT SPINDLES
REAR SUSPENSION: MAXIMUM MOTORSPORTS ADJUSTABLE LOWER CONTROL ARMS, CUSTOM TORQUE ARM, MAXIMUM MOTORSPORTS PANHARD BAR, 3 WAY ADJUSTABLE KONI COIL OVERS, MAXIMUM MOTORSPORTS ADJUSTABLE ANTI ROLL BAR.
CHASSIS: MAXIMUM MOTORSPORTS SUBFRAME CONNECTORS, DRIVESHAFT SAFTEY LOOP, MAXIMUM MOTORSPORTS 4 POINT ROLL BAR, ALL SPOT WELDED SEAMS FULLY WELDED
BODY: FIBER TRENDS HEAT EXTRACTOR COWL HOOD, AUTOMETER GAUGES INCLUDING SPEEDOMETER AND IN DASH TACH, SUMMIT RACE SEATS, 5 POINT RACING HARNESSES WITH QUICK RELEASE, AIR BAG DELETE, REAR SEAT DELETE
WHEELS AND TIRES: FORD SVT RIMS, TOYO PROXES R888 245/40ZR17
Located in Tuscarawas County, OHIO, Send questions to [email protected] or call/text 740-922-5719
1 - 1 of 1 Posts
