Year:1988
Make:Ford
Model:Mustang
Mileage:107690 M
Transmission:Automatic
Engine:N/A
Trim:LX
I am the 2nd Owner and the car currently has 107,690 Original Miles, of which approximately only 2,500 miles have been put on the many upgrades. Car has always been garaged since purchased in 2013. It's really fun to drive, fires right up & is ready to go. Motor was taken down to Stock Short Block and all new Top End added. Engine upgrades include GT40P heads with Trickflow Valvetrain, Ford High Performance Lifters and Pushrods, Explorer Intake and Throttle Body, Trick Flow Stage 1 Cam, 24 lb injectors, Fuel Pressure Gauge and Regulator, Water Pump, Radiator with Electric Fans, 3G Alternator 130 Amp Kit High Output Ignition Coil Pack and Ford Racing Spark Plug Wires. A Brand new AOD Transmission was built and professionally installed by Mike's Transmission (Good for 500+ HP) and includes a Lentech Valvebody, 3000K stall converter, Cooler with built in Electric Fan, custom lines with screw on filter. You can manually shift this Transmission with each gear accessible or just leave it in drive for fully automatic function. Also includes overdrive lockout at the flip of a switch. Really makes the AOD a blast to drive! Exhaust was replaced with Mid Length Ford Racing Headers for GT40P Heads, Off Road MAC H Pipe (To be included, Not on Car, Currently has on the Stock Cats) and a Flowmaster Cat Back. Rear end upgraded with 4.10 Ford Racing Gears. Suspension was upgraded with Strange Front Coil overs with Adjustable Shocks, Caster/Camber Plates, Rear Ford Racing Lowering Springs, Quad Shocks were removed, replaced with Strange adjustable Shocks and Aftermarket Upper and Lower Control Arms added. New Mickey Thompson Sportsman Comp up front and older M&H Drag Radials on Rear are installed on the Stock 10 hole wheels. Also have a set of 17X9 Cobra Anniversary Wheels with Mickey Thompson Street Comp Tires to be included with car and have less than 100 miles on them. New Carpet, Front Seats and Radio Delete Panel with Gauges added to interior. A/C and Heater work great, as do the Power Mirrors, Windows and Door Locks. Additional items added include Cervinis Heat Extractor Hood, Front Brake Rotors and Pads, new Ford Motorcraft Battery, 250lph Fuel Pump, Clear headlights, Cobra Grille Insert, new weather-stripping in Box to be included with car, . *Title in hand and DMV fees are current. Selling AS IS with Buyer responsible for smog.
(559)871-5203
[email protected]
