Ordered a K24A from JDM Engine Depot in NJ. Showed up freight in less than a week. Engine build:
Stock internals K24A
ARP Head Studs
Type S Oil Pump
Unit 2 Baffled Oil Pan
Touge Factory Turbo Manifold
Tial Wastegate and BOV
KPower Intake Manifold
KPower EP3 Pully
KPower B series 74mm Throttle Body
Garret GT3076R
Touge Factory RWD coolant goodies
Remote Oil Filter
FIC 1000cc Injectors
Radium Fuel Rail and Regulator
K24 cleaned up and turbo manifold fitted:
Now the K24A use a slightly different water pump housing than the USDM K- series engines. The alternator mounts from the front vs the side and you cannot easily source JDM alternators in the states so off to pick and pull for the correct housing. Picked one from a 2007 Element:
JDM left USDM right
USDM unit mounted with a fresh water pump, tensioner and ep3 pully. The ep3 pully replaces the power steering pump:
New coolant fittings to suit a RWD conversion:
Have to relocate the oil filter to clear the turbo manifold. Has a threaded port for turbo oil supply too:
Pulled the valve cover to add some breathers:
ARP Head Studs
Type S Oil Pump
KPower EP3 Pully
Garret GT3076R
Remote Oil Filter
JDM left USDM right
