ok, this is the first time i've ever done this myself. i fried my clutch a month or so ago, and have finally got the motivation and time to fix it. well, the tranny wasn't no big deal (since i've done that a few times). well sunday i finally ventured down to the garage to take the bellhousing and clutch out. well, that was no big deal either, however, when i went to take the flywheel off, the motor kept turning. any suggestions on how to take off the flywheel?
Either use a impact wrench or buy/rent a flywheel tool. The tool lets you grab the teeth of flywheel and keep it from moving. Impact wrench is easier for disassembly and tool for install.
Use a prybar (loooong screwdriver) and jam it between the ground and the teeth of the flywheel to prevent the motor from rotating...
