I'm fixing a rusted floorpan from a leaking heater core. There's this tar/rubber stuff that I had to remove (it's some kind of sound deadener). Where do I buy this stuff to replace it? I thought about spaying some rubberized undercoat then putting a sheet a plastic over it after I'm finished fixing the rust, but I would rather do it right.
Also, where can get carpet insulation?
A bodyshop supplier should be able to get you what you need to do it right. I know we have 12"x12" sections of self adhesive sound deadener pads at work, that tar stuff, just like stock. It can be cut, heated and moulded to whatever shape you need.
Try using ice and water shield for roofing. It deadens sound and is waterproof. I used POR 15 on my floors first so they will never rust again.
