1 - 20 of 42 Posts
List of current mods:
4.10s
31 Spline Moser axles
TrueTrac
P1SC w/ 3.6" pulley
108" belt
75mm TB
C&L Plenum
Cobra hat and pumps
42lb Injectors
o/r H-pipe
Flowmaster 50 series catback
Stock manifolds
Steeda SFCs
MM HD LCAs
Steeda Sport springs
Discussion Starter #2
Found out the bypass valve wasn't working because the screw on the butterfly valve was loose. Just took it for a drive and it runs way harder! I'll be back at the track tonight.
what kinda power numbers are you making? i ran similar et's with i believe higher mph last year with 413 hp and 450 rwtq.
I don't know how much power, it was tuned on the street. But since I fixed the bypass this morning, it runs a lot better. Hoping for a better ET tonight. But even last night, I was running out of gear, so can't do much more about trap speed until I get my 27" tires mounted.
gotcha. we only have 1/8 mile around here. sadly i did not hit the track this year. maybe in the next couple weekends i can go before it closes. saw your project thread about putting on the blower and all that. nice thread. good luck tonight hope you can break some better #'s. that 60 ft aint too bad. what were you running on for that, dr's?
Thanks!
Believe it or not, Nitto NT555's(not DRs) 275/40/17.
dang, that's pretty good then on pure street tires. surprised your 60 ft is that low. i couldn't get much better bfg dr's.
These tires usually suck, but the track was prepped pretty damn good last night.
Nice runs. My 12.9 looks almost identical to yours.
How were you launching to get the 1.91 60ft?
Thanks.
Honestly, I'm not sure what RPM I was launching at. I usually just go by sound, but probably around 2500. And I just come off the clutch really fast, but not quite dumping it. There were a bunch of big tire race cars going that night, so that helped a ton.
After you release the clutch, wait til it bites and then floor it?
I was see sawing clutch/gas last time for a 2.0. Pretty inconsistent though. It's either an ok 60 or smoking the tires.
Sent from my iPhone using Autoguide.com Free App
Cool. Thanks. I'm going to try that next time.
How about burnout and tire pressure?
Discussion Starter #15
I run my Nittos at 18 psi.
I go around the water box, back up a little, then rev it up, dump the clutch and burnout til I feel it starting to catch, then let out, back up, and stage.
BTW, I don't use the brake when I burnout. I just go down to about the where the lights are. LOL.
Once I get the Hoosiers on some rims I'm gonna have to learn how to do a real burnout. Ha
111mph will get you into the bottom 12's/very high 11's, but your 60ft's are horrible lol. you'd need a 1.5
you'll enjoy the qtp's
Nice times.....doing better than me lol......i only did a 13.4...im confused lol
Discussion Starter #20
Dang.. No good!
I am getting the Mondo welded on some time this week, then retuned at the track hopefully Friday or Saturday. I should have my wheels and tires by then too. I'm hoping for low 12's.
Do you know of any obvious problems with your setup to be running like that?
1 - 20 of 42 Posts
