My 2000 GT has started acting fishy at the first startup of every day. Problem is that it misses, farts and struggles for about 10 seconds after startup. This only happens when it has been sitting overnight, and never if i drove it already that day. Upon startup the RPMs jump to 2 grand like normal then fall to about 5-600 and struggle unless i give it a little gas, then it will even out to the 8-900 it should be at after about 10 seconds.
This is not a big issue but very annoying because i want everything to be perfect with this car.
Here is what i have done recently.
New IAC valve a couple moths ago
Throttle Position sensor about the same time
Fuel pump about a year ago
Fuel regulator at same time
My theory is that the IAC valve is crappy(BWD brand) from advance auto which i had to switch out a couple times to get running right in first place cuz the first 2 were defective.
1. I think maybe it sticks first startup of the day.
2. Failing oxygen sensors
3. Fuel pump is not pushing good, clogged filter or maybe dirty sock on the pump.
4. maybe a MAF sensor issue somehow
Any experience with this, what are your opinions.
I will double check if there are any codes, today was a cold morning and it stalled on startup for the first time. hopefully it threw a code over this issue.
