I would first verify timing. Disconnect the vacuum line on the distributor and cap it, the hose not the distributor. If you want to run the vacuum advance, its optional, the vacuum hose should be from distributor to the timed spark port on the side of the metering block on the carb. If timing looks good check to make sure fuel is coming out of the squirter when you whack the throttle. A pop through the carb can be a lean pop sometimes. Could be bad accelerator pump or out of adjustment.
What size primary jet and squinter? What size power valve? Heads, cam, exhaust? Power valve will be determined by how much vacuum it is pulling.
To tune it you will need a vacuum gauge and hook it up to the large port on the bottom of the carb. Try to adjust the mixing screws at idle for the most vacuum. Turn them in and count how far it went it. It should stall all the way in. Back them out a turn and watch the gauge.
Holley has a ton of good videos on youtube that make it pretty simple.
