1 - 12 of 12 Posts
Hi guys, I just got done with my head swap on my 93 coupe. I put tfs heads/intake and tfs stage 1 cam in it. I got it started and let it idle for a while then drove it around, everything was fine. Then I parked it and now it wont start. I left my alt. unplugged so I thought that I might have killed the battery, but I got it recharged. All it will do is click, and maybe crank once weakly. What could be wrong. I have no clue, help me out guys, thanks Chase
well clicking is a dead battery, whatever reason its dead
I thought it was the battery but like I said, I went and had it recharged. Someone told me that the distributer might have game loose after playing with the timing, but that does not seem to be the case. I really want to get my car going, any other suggestions, this car is my daily driver. Thanks Chase
Pull all the plugs and try to turn it over. It's possible a cylinder filled up with water :(
I dont see how?
87gt dude!! You spent 2k on all the stuff you just did, Do not let a little 50.00 battery ruin it for you. ITS YOUR BATTERY!! GO GET A NEW ONE!!!
Discussion Starter · #8 ·
Its not my battery, I just pulled the plugs, and now it cranks, so does that mean I have water in my cylinder. help anyone
The battery could be weak and having trouble against the compression, or you could have a poor electrical connection somewhere.
If you have water in a cylinder, there should be some evidence of that, but you may have to turn it over by hand to check each cylinder.
really no plugs in and it turns over yet another miracle.
lol, Once again get another battery, or atleast try another battery from another car.. It will work then...
1 - 12 of 12 Posts
