Its been a while since I installed the pnp2 on my 88 mustang, I really don't remember much about it. Does this system utilize the factory air charge temp sensor and coolant temp sensor?
Yes. It can use any thermistor suitable for 3-point calibration and the Ford sensors are. With a PNP the calibration should already be set unless you changed it or wrote a new tune where it's different.
The calibration is done under tools->calibrate thermistor tables.
How it works; physically inside the megasquirt there is a bias resistor, with a PNP2 I assume it's the standard value.
Calibration settings then are:
Bias resistor value 2490
33F = 94000
123F = 11000
208F = 2370
Taken from this page.
https://www.diyautotune.com/support/tech/install/ford/megasquirt-your-mustang-5-0/
Thanks, I was just thinking about replacing the sensors with new ones to be sure they're working properly but wasn't sure if the megasquirt even used them.
Won't work without them.
The sensor setting in the PNP are set to stock sensor calibration. My ECT was a parts store replacement and was way off. I had to change the calibration settings to match that sensor. It was showing 60 degrees higher than actual temp.
