:confused: How much is tooooooo much for the factory fuel system? Got into a conversation about a factory fuel system with a friend of mine and we cannot come to a conclusion.
:255 intank pump, t-rex inline, and paxton rails with a regulator.
How much Hp is the above mentioned system good for? Lets get to the bottom of this please. If anyone has seen testing of this please also advise.
It all depends on the motor/power adder setup. I made ~550rwhp with just a 190lph intank, stock lines,stock rails, adj. fpr, and 30lb injectors using a 150hp shot wet nitrous kit. With your above setup...i could see probably 650rwhp using a wet nitrous setup. But probably only 500-550 rwhp on a forced induction combo requiring higher fuel pressures.
I believe the stock fuel system is way underrated.... There are a couple people I know of who are running stock rails, lines, filter, 255 in tank, 255 in line, Kirban reg, 42's making 570-600 to the tires Turbocharged..
Jeremy
